In the schematic I just wanted to make sure I got this right. For VCC and VCC/2. I know VCC means the power supply(voltage common collector) but for VCC/2, this just stands for the power being split, correct. And couldn't I just have the two 10uf capacitors that are in series together with the circuit be right after the voltage divder(the two 10k ohm resistors in series) instead of being after the TLC222. And then from there have a designated line on my perfboard that is connected to VCC/2,strictly used for components that need VCC/2.
Also, the Box's labeled VCC and VCC/2, why have these? Instead of the Letters VCC and VCC/2?
