Questions about Solder
Discussion in 'General Electronics Chat' started by Management, May 26, 2009.
  1. Management
    Thread Starter Active Member
    Sep 18, 2007
    306
    Does anyone know the electrical properties of soder?
    For example:
    Conductivity? Or how many times less conductive it is than Copper?
    It's relative permittivity (Er)? I want to calculate the capacitance it creates between two metals.
    Thank you.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. studiot
    Nov 9, 2007
    5,005
    515
    Capacitance?
    Solder is still a conductive metal (alloy).
    There is no electric field within a conductor
  4. radiohead
    May 28, 2009
    474
    31
    Basically when you solder, you are making a low temperature weld. Considering the small amount of solder used to connect a 30 AWG wire to a 1mm copper pad on a CCA, the amount of resistance is negligible. Typical solder is 60/40 lead/tin alloy with a rosin core, but you will still need paste flux to make the solder melt evenly. Never use acid core solder on electronics, acid core solder is used, for example, to repair automotive radiators and will corrode electronics.
  5. studiot
    Nov 9, 2007
    5,005
    515
    Soldering is not welding.
    In welding you are using a joining material that is the same, or very similar, as the parent material (plastic or metal) and trying to create a continuous crystal structure across the joint.
    This does not happen when soldering.
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    You do get limited alloying where the solder meets the metal, and the solder and the metal must be compatible with each other (with some exceptions). Once the wire material is "tinned" then you aren't going to get it off, not easily at least (some chemistry required).
    Gold wire bonding is slightly similar, in that there is some alloying going on.
    Because lead has been declared evil and almost as dangerous as mercury (to which I declare BULLCORN!) most modern devices use a form of silver solder (3-5% silver, 95-97% tin). Turns out the new blend grows dentrites like crazy, and is not considered acceptable for military or space use. Meanwhile old fashioned solder is getting harder and harder to find. I bought around 5 pounds of it last ham con I went to, probably a lifetime supply.
