The MOSFETs appear to be undamaged. I used a multimeter to check continuity/resistance against the gates and they measure the same as fresh ones i have not touched yet.
No shorts against any of the legs and there was a 640ohm resistance across the drain and source if the black lead is on the drain and red was on source. I assume this resistance is because of the built-in diode from source to drain on the MOSFETs
All I did the last time the driver died was replace it with a new one and try it on the bench with the same MOSFETs on a small DC fan and the circuit worked, controlling the fan speed and all. once I put it on the big 30A motor, it blew up and cracked in half.
