questions about power
Discussion in 'Homework Help' started by fl415, Sep 13, 2011.
  1. fl415
    Sep 7, 2011
    Find the total power developed in the circuit in the figure if v0=5v
    find v1 and v2 in the figure
    find i0 and ig in the figure
    thank you so much! the third circuit is a bit confuse me, should i find the Req first? or just use KVL straight?
  2. fl415
    Sep 7, 2011
    Can anyone help me??
  3. Jony130
    Feb 17, 2009
    3,991
    1,116
    You need to post your attempts first, then we can try to help you.
  4. tgotwalt1158
    Member
    Feb 28, 2011
    111
    18
    First problem needs some elaboration. For, 2nd and 3rd, I have solved by paint, see the attached files.
