Hello.
I'm firstly asking you that you may want to see the attached image Recently we have used coaxial cable to transport power to the load (plasma) in ICP (Inductively Coupled Plasma) experiment. We had chosen coaxial cable with expectation that it minimize radiation from the cable. The basic assumption of such a choice was that current of central conductor of the cable at certain position z is equal to the current of ground at that position (mesh shield) except for direction. (in other word, out of phase). Mathematically it means Δφ is zero in the attached picture. (Z_eff represents equivalent impedance covering the load and wires between the coaxial cable and the load)
However, my colleague said radiation from the cable was measured with significant strength such that nearby instrument became malfunction. I said radiation source should not be the cable itself but the other becuase of current cancellation within the cable but it looks he didn't believe me.
So now, I'm also confused about my original concept. Does the coaxial cable have current cancellation within itself no matter what external connection is done to it or is case dependent? (for example, even for the case that two wires connecting the cable and the load have different length and composition?)
If it is latter, what factors should I take into account?
