Questioning about RF transmitter and receiver
Discussion in 'Wireless & RF Design' started by supar, May 3, 2013.
  1. supar
    May 3, 2013
    2 x RF transmitter 433 MHz
    2 x RF receiver 433 MHz
    How I need to avoid these 2 set of RF transmitter & receiver from conflict each other? Let's say (RF transmitter and receiver set 1) won't interfere (RF transmitter and receiver set 2)? Please help me
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Have them operate on different frequencies within the band of interest, or separate them by a suitable distance for their power levels.
  3. supar
    May 3, 2013
    How to make them operate on different frequencies within the band of interest?
  4. nerdegutta
    Dec 15, 2009
    2,565
    805
    You can separate them with different ID's.
  5. supar
    May 3, 2013
    Do u mean the address-bit?
  6. nerdegutta
    Dec 15, 2009
    2,565
    805
    Since nothing else is specified, I took for granted that you are talking about these:
    433 Mhz
    You can then separate them in the uC's software.
    If these are not what you mean, then you need to specify what type/model with datasheet.
  7. supar
    May 3, 2013
    yaya, im planning to use components similar to that. my idea is use them with 8-bit address encoder/decoder, that mean after i set the address bit for (transmitter and receiver set 1) to let say 10000001, then it will not interfere with (transmitter and receiver set 2) with address bit 01100110? izzit correct?
  8. nerdegutta
    Dec 15, 2009
    2,565
    805
    What are you trying to do? Please give more details,with schematic and component list. That would make it a lot easier. :)
  9. WBahn
    Mar 31, 2012
    18,085
    4,917
    What you are talking about is known as Medium Access Control, or MAC, and there are many ways to go about it. It is pointless to talk about specifics until you provide information about the capabilities of the hardware you are using.
    In general, setting an ID code will not help to prevent RF interference unless the ID code is somehow used in the MAC protocol (which includes being used to establish a hop sequence of spreading code for a spread spectrum system).
