question
Discussion in 'Homework Help' started by abhin.vicks, Feb 10, 2013.
  1. abhin.vicks
    Jan 26, 2013
    7
    whats dis?....can u tell me
  2. WBahn
    Mar 31, 2012
    18,094
    4,920
    Dis iz scanz uf sirkutz?
    Could you at least TRY to ask a coherent and meaningful question?
    tshuck likes this.
  3. thatoneguy
    Feb 19, 2009
    6,357
    718
    1. dis
    1.to disrespect some one
  4. toffee_pie
    Oct 31, 2009
    162
    7
  5. DumboFixer
    Feb 10, 2009
    219
    34
    <insert standing ovation smiley here>
  6. t06afre
    May 11, 2009
    5,939
    1,222
    It is the wheatstone bridge configuration. Just Google wheatstone bridge
  7. atferrari
    Jan 6, 2004
    2,674
    785
    Heard of the four figures game?
    Your texting is very good!
  8. toffee_pie
    Oct 31, 2009
    162
    7
    i can haz help with dis qustion plz ?!
  9. djsfantasi
    Apr 11, 2010
    2,916
    881
    Perhaps the guidelines for posting in this forum should explicitly discourage text speak. To toffee_pie, English is the forum language and questions should be posted clearly in normal language. Text speak is discouraged (and often disparaged) by many members, so if you respect them, you will get better answers.
    For example, "I can have help with this question, please?" is much more likely to get a valuable response.
  10. toffee_pie
    Oct 31, 2009
    162
    7
    hmmm
    clearly my sacrasam was lost on you.
  11. #12
    Nov 30, 2010
    16,705
    7,358
    That is a common problem. Emotions don't travel well over a keyboard. MANY of my attempts at jokes have been ignored. I finally learned to use smileys.
    go advanced and drag one over.:eek:
  12. kb9ttx
    Jan 29, 2013
    Each of the four figures are equivalent circuits.
    At first, I was uncertain of the validity of the assertion that these were really equivalent circuits.
    • Figure 2 is a simple re-drawing of the first figure. Thus, it was not hard to accept these two as being equivalent.
    • Figure 3 is equivalent to Figure 2 only when all of the resistors are the same. If one were to replace 1 ohm with R and perform a nodal analysis, one would find that Figure 3 is equivalent to Figure 2 regardless of R. However, if any one resistor is something other than R, then the circuits are no longer equivalent. Setting R = 1 ohm, makes the math easy.
    • Figure 4 can be found by adding the series and parallel resistors to find "Req". Again, this is only valid when each resistor is the same value. In this case, R = 1 ohm.
    I am not sure what you really want to know or if you even really wanted to know anything about these figures. Nonetheless, I enjoyed brushing up on my circuit analysis skills. :)
