I want to use one normally open contact to work as ON button
one normally closed contact to work as OFF button
one relay
one light source
+5V supply and ground
the same +5V is the power supply for light source also
Now my question is as follows:
When I hit ON the light should stay ON unless I hit OFF
Once I hit OFF the light should stay OFF unless I hit ON
How should I connect these contacts alongwith the relay to achieve the above?
If anyone has an idea please let me know
one relay
one light source
