Question
Discussion in 'The Projects Forum' started by crash1555, Nov 23, 2008.
  1. crash1555
    Nov 19, 2008
    Hello
    i was wondering if it is possibly with basic electronic components to create a circuit that would put out a signal at around 34 ghz?
    if so (and if anyone has any extra time) could someone make a schematic up?
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Most typical off-the-shelf transistors are limited to under 300MHz.
    A few more might get somewhat close to 1GHz.
    Even attempting to tune relatively simple LC filters in the 2GHz to 9GHz range is daunting. The higher the frequency, the more that parasitics come into play.
    There isn't a way for a lay person to successfully create a circuit at that high of a frequency.
  3. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
