question
Discussion in 'General Electronics Chat' started by dlmcknny63, May 26, 2008.
  1. dlmcknny63
    May 25, 2008
    11
    what is the inputs of A and B if the output of a two-input NAND gate is a zero
  2. mik3
    Feb 4, 2008
    4,846
    63
    The inputs may be
    A=0, B=0
    A=0, B=1
    A=1, B=0
    If the inputs are A=1, B=1 then the output is 1
  3. dlmcknny63
    May 25, 2008
    11
    Thank You Sir...........:)
  4. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Methinks there be a typo here...:confused:
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    No soup for you!
    NAND truth table:
    Code ( (Unknown Language)):
    1. A B |Out
    2. ----+---
    3. 0 0 | 1
    4. 0 1 | 1
    5. 1 0 | 1
    6. 1 1 | 0
    [eta] No soup for me, either! :D
  6. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Methinks there STILL be typos here!:rolleyes: No soup for either of you!
    "NAND" means "NOT AND." (But you knew that.) "AND" means both i/p must be high for the output to be high. (But you knew that.) "NOT" means, we invert the output. (But you knew that, too.)
  7. mik3
    Feb 4, 2008
    4,846
    63
    Ohhh!!! You are right thingmaker, he wants a NAND gate and not an AND gate. I was not very carefull and i didnt notice that. Thus the correct answer is:
    You get a 1 on the output if
    A=0, B=0
    A=0, B=1
    A=1, B=0
    If the inputs are A=1, B=1 then the output is 0
    I am sorry for the wrong answer dlmcknny63
