I just voted for you; send pork.The only way I ever won an election: run unopposed.
I guess #12 votes 12?
Max.
When I train young dogs, I try not to develop bad habits in them that I'll have to break later.Semantics. Please don't pee in the soup. The beginner is having enough difficulty.
How will increasing the current cause the resistance to drop? If the voltage is staying the same, how will you increase current in the first place?Assuming voltage stays the same then an increased current will return a drop in resistance and vice verse, this pretty clearly shows that resistance is central to the flow of current itself.
I like the word "restricts" better than "opposes". "Opposes" implies "equal and opposite". And "oppose" is not a synonym for "restrict".A resistor opposes current in the same way that a water valve opposes water flow. It's a restriction. More power (voltage or pressure) must be supplied at the source to maintain the same flow at the output, with the excess power being dissipated at the restriction. If more power is not supplied, the flow decreases.
Just as with water, the flow on either side of the restriction is identical. No extra water mass or electrical charge is added or removed, only energy.
by Jake Hertz
by Aaron Carman
by Aaron Carman
