Question with a compensated integrator circuit?
Discussion in 'Homework Help' started by uofmx12, Aug 24, 2011.
  1. uofmx12
    Mar 8, 2011
    55
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Probably to provide short term compensation of the (non-ideal) amplifier input offset voltage, which in the uncompensated state would lead to a drift in the mean value of the integrator output. At worst case this might lead to the output drifting up or down to saturate near either supply rail. The compensation may require periodic re-adjustment since the input offset itself tends to drift with things like ambient temperature variations and the passage of time.
