Question the load
Discussion in 'General Electronics Chat' started by superway, Feb 2, 2012.
  1. superway
    Thread Starter Active Member
    Oct 19, 2009
    128
    Enclosed is my simple circuit. What is the purpose of 4000W / 1 Ohm connect in series with AC source? Can anyone help?
    CN
    • DOC.pdf
      File size:
      11.8 KB
      28
  2. mrmount
    Dec 5, 2007
    59
    7
    If in case there is a short circuit in the unit being tested the 1 ohm 4000 W resistor will dissipate the power and will not damage the power source ? My guess would be that...
  3. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    an end use would likely give insight into the configuration. what mrmount said, or possibly current limiting for the device under test. Fuses for instance can be classed at 5Kamp.
  4. BillB3857
    Feb 28, 2009
    2,402
    348
    Possibly a means of indirectly measuring current. 1V/Amp. Of course the load would see that voltage deducted from the supply source voltage.
