Question regarding return currents for high-speed signals
Discussion in 'General Electronics Chat' started by nickagian, May 28, 2015.
  1. nickagian
    Thread Starter Active Member
    Mar 12, 2010
    34
    Hi guys,
    I have this question: It is common knowledge that for high-speed signals the return currents are flowing directly beneath the signal PCB lines, over some power or ground plane. And for that reason one should pay attention when such signals cross over breaks in the planes. So assuming we have the following PCB stack-up:
    1 -> Signals and Ground
    2 -> Ground
    3 -> Signals
    4 -> Power supply planes
    (bigger distance than between the other layers)
    5 -> Power supply planes
    6 -> Signals
    7 -> Ground
    8 -> Signals and Ground
    So for signals on layers 1 and 8, the reference layer for return currents are layers 2 and 7.
    But what about signals on layers 3 and 6? Is it 4 and 5 or again 2 and 7?
    I have seen some PCB designs where it is implied that the return currents are flowing over 4 and 5.
    I hope it is clear what I am asking!
  2. kubeek
    Sep 20, 2005
    4,687
    805
    Well the return must obviously be through ground, but if the distnace 2-3 is the same as 3-4 then there will also be induced AC currents in the power plane as well.
    nickagian likes this.
  3. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,686
    1,297
    And, the currents in the power planes will run into breaks that are not there in the ground planes. So the signal trace will be a full stripline most of the time, with impedance bumps where there are breaks in one plane but not the other. Over the power plane breaks the signal will act as a microstripline for that short distance.
    ak
  4. alfacliff
    Dec 13, 2013
    2,449
    428
    check out microstrip, stripline and microstrip sre a bit different, one uses two ground planes, one above and one below the signal line. also, for high speed data, any paralell data lines must be treated as transmission lines for poth impedance, and any curves must be treated like stripline or micorstrip to prevent reflections and differences in time.
