Question regarding Norton Equivalent Circuits and Inductor current.
Discussion in 'Homework Help' started by Robert Murch, Nov 2, 2015.
  1. Robert Murch
    Nov 2, 2015
    8
    Hello everyone reading thanks for taking the time to try and help me. I have uploaded and image of the question and the work I have done so far: img1.jpg
    The problem I am having is coming up with the differential equation that describes the current through the inductor. I know that for a capacitor and a Thevinan equivalent circuit I would simply use kvl and then do some substitutions. However, for this Norton equivalent circuit with and inductor, I cannot seem to figure out how to come up with an equation describing Il2 (as labled). I tried kcl at the top node(Vx): -In +3/Vx + Il2 = 0 but then I couldn't describe the voltage Vx. I also tried two current loops, first loop: 3(In - Il2) = 0, second loop: 3(Il2 - In) = 0. However that seems to suggest that Il2 = In which does not seem right. Can someone tell me where I went wrong or what I need to do after this step if I have done everything correctly so far?
  2. WBahn
    Mar 31, 2012
    18,093
    4,918
    One of the problems is that you ended up with Is (the original current source) as your Norton equivalent current source. Does that make sense? What was the point of finding Isc just above it?
    From the statement in your post, "I tried kcl at the top node(Vx): -In +3/Vx + Il2 = 0," if you would track your units you would see that this is guaranteed not to work. The first and third terms are currents while the middle term, 3/Vx, should be 3Ω/Vx, which will have units of 1/ampere.
  3. Robert Murch
    Nov 2, 2015
    8
    Okay I seem to have left it as 10sin(2t) when I meant (10/3)sin(2t) which is Isc. Using -In +3/Vx +Il(t) = 0 can i not just substitute Vx as L(dIl/dt)? I did that and came up with (10/3)sin(2t) = (1/3)L((d/dt)(asin(2t)+bcos(2t))+asin(2t)+bcos(2t). Where the forcing function Il(t) = asin(2t)+bcos(2t).
  4. WBahn
    Mar 31, 2012
    18,093
    4,918
    Look carefully at : -In +3/Vx +Il(t) = 0 (which should be -In +3Ω/Vx +Il(t) = 0)
    What does the first term, -In, represent? A current, yes?
    What does the third term, +Il(t), represent? A current, yes?
    What does the second term, +3Ω/Vx, represent? Hint: It is NOT a current!
    But, in order to add them altogether, they MUST have the same units -- you can't add gallons and feet.
  5. Robert Murch
    Nov 2, 2015
    8
    Oh geesh yeah your right sorry it should be the other way around Vx/3. Once again I ended up writing it into my equation as (1/3)(Vx) but was typed up incorrectly.
