Question regarding MP1584EN IC
Discussion in 'Electronics Resources' started by Peter5510, Jan 19, 2014.
  1. Peter5510
    Jan 19, 2014
    Hi All,
    This is my first post in this forum. Since this is my first post, I don't think I can post a link to the datasheet. This IC is on driver board of an Acer LED monitor. One of the zener diodes connected to this IC is shorted. I check the IC with multimeter and pin1 is shorted to ground. Is this IC still OK ?
    Thanks in advance.
  2. crutschow
    Mar 14, 2008
    13,492
    3,372
    Where is the zener connected to the IC?
    If pin 1 is shorted to ground then the IC would appear to be zapped.
  3. Peter5510
    Jan 19, 2014
    Thanks for your reply.
    The zener diode is connected to Pin 1. I desolder the zenered diode and it measured OK with a multimeter. This leads me to think that the short lies elsewhere. Anyway, I replaced the MP1684EN IC but it didn't fix the problem. Nearly killed the board because I didn't fully desoldered the ground pad of the IC. :(
