Question regarding Linear actuator
Discussion in 'The Projects Forum' started by davis103, Jun 24, 2008.
  1. davis103
    Jun 9, 2008
    27
    Hey everybody:
    I am planning to buy a linear actuator. I am not familiar with them. My question is: If i apply voltage to it and extended to a desired position and then remove to supplied voltage, does it lock in that position even if i try to contracted?
    Second question is i want to make sure this actuator when one polarity is applied then it extends and if i apply the reverse polarity then it contracts.
    Am i correct?
    I appreciate all your information.
  2. davis103
    Jun 9, 2008
    27
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    I used one from Saginaw with a 40" stroke. It stopped moving, but had no brake applied with power off.
    Find out who makes it and get the specs from the manufacturer.
  4. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    10:1 gear ratio suggest the actuator would at least be difficult to move when the power was off, but is no guarantee of "locking in place."
