Question re: toroidal transformers
Discussion in 'Homework Help' started by rgarigliano, May 24, 2013.
  1. rgarigliano
    May 24, 2013
    Can a dual output toroidal be configured like a center tap trans? ie. use one of each out put as ground and the remaining two a + and - ....
  2. t06afre
    May 11, 2009
    5,939
    1,222
    From your description, I would say yes go on. However the knowledge on how to dimension a transformer correct are often something that are missing. So please take a look at this document. It will show you how to wire up the rectifier, and spec the transformer
    http://www.audiofaidate.org/it/materiale/20_020_020_001_PowerTransformer_FilterRatings.pdf
  3. rgarigliano
    May 24, 2013
    Thanks. The linked document was very helpful...
