Question on this circuit
Discussion in 'Homework Help' started by kirit, Sep 21, 2008.
  1. kirit
    Thread Starter Active Member
    Sep 9, 2008
    35
    Working on this lab and I think I have everything down except the Currents: I8, I9, I10. Im looking near resistor 5 and it seems to have arrows going in 2 directions. Is that right?
    thanks.
  2. veritas
    Feb 7, 2008
    167
    Whether it is correctly labeled or not, the current will just have the opposite sign for directlion. The arrow pointing up doesn't seem to have a label though.
  3. liitlefan
    Sep 24, 2008
    7
    i think u r wrong ~~
    most of arrows i your picture i think is wrong~
    current flow from node with high voltage to lower .
  4. skiptoo
    Sep 24, 2008
    I'm afraid kirit's answer was wrong
  5. skiptoo
    Sep 24, 2008
    Cause no current would flow in two directions,I agree with littlefan
  6. veritas
    Feb 7, 2008
    167
    Current "flows" in whichever direction you specify on your diagram. It might be negative (in the opposite direction as the arrow), but you can still calculate it.
    On the other hand, real electrons flow in the direction OPPOSITE to which we normally consider current to flow -- towards the lowest electrical potential.
