question on schematic
Discussion in 'The Projects Forum' started by prescott2006, Feb 25, 2010.
  1. prescott2006
    Thread Starter Active Member
    Nov 8, 2008
    72
    is the another leg of the led in the red rectangle connected to ground?because i see it is floating there..
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    No schematic is visible. Please post it.
  3. MikeML
    Oct 2, 2009
    5,450
    1,066
    If these are LEDs, then the other end (cathode) is connected to GND, just like the one labeled LLO and LPWR.
  4. leewillz
    Member
    Jan 11, 2009
    17
    should be connected or else they simply wont light up
  5. kubeek
    Sep 20, 2005
    4,686
    805
    Between those two pins could also be a bi-colour LED, so that one pin high and the other low makes one of the colours light.
  6. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,382
    To look at the schematic it looks like a guitar tuner.
    The program in the PIC compares the input from the guitar with a reference in the PIC.
    As far as I can see there are three of those contacts.
    Probably the pins have the following function:
    LLO , a led for a to low frequency.
    LOK, a led for an OK frequency.
    LHI, a led for a to high frequency.
    I think the site where you found the schematic will have more info on it.
    Greetings,
    Bertus
