Some friends of mine are moving into an apartment building that contains its own hydroelectric generators, and supplies all of its own power. The website claims they generate 6 Million KWH annually, of which they consume 4m kwh and sell 2m kwh to the utility. The math works out to a generating capability of almost 700 kw. US based, so 120v 60hz.
My question is: Since this building is a somewhat closed electrical system and lacks the "inertia" of a larger electrical grid, is it more susceptible to distortion of the waveform, surges, and under-voltage? Will someone turning on a dryer affect the entire building?
I ask because if the smaller electrical system is more susceptible to harmonics and surges, investing in a UPS with line conditioning for sensitive electronics may be well worth the cost.
