question on ir2304
Discussion in 'The Projects Forum' started by whocare1987, Nov 11, 2007.
  1. whocare1987
    Nov 11, 2007
    i am using the ir2304 mosfet driver to drive a h-bridge mosfet which i cant make it work.
    the mosfet is IXFN 230N10
    i would like help in the value of the cap that i need to use.
    and any other connection do i need to add from the test circult connection to make it work
    the pwm input is 1kHZ.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    A schematic would really help to see why your circuit doesn't work. If the gate of the FET is raised 10 volts above the source potential, the FET should be turned on.
  3. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    For clarification, are you using two each ir2304 to drive four each IXFN 230N10 in H-bridge configuration?
