Wow thanks Mr AI. That's also very enlightening to me. The fact that the nf is used to control the accuracy of Vo wrt Vin. I mean, I have read so much about opamps in the past 3 weeks but its all theoretical.
Vout will go down with Vn (the inverting input) because that input always causes Vout to go down when it goes higher in voltage. But the reason for negative feedback (rather than just applying a separate voltage) is to make the amplifier characteristics better.
One of the main advantages to negative feedback is accuracy of the output voltage with respect to the input voltage at (in this case) the non inverting input Vp. The negative feedback makes up for the deficiencies of the open loop gain which is not well specified and is not stable over temperature. The closed loop gain is highly predicable and stable, and that comes from negative feedback. The drawback is we loose some of the original gain in the process. Even so, it was probably one of the most important inventions in electronic history.
A better overall view of the op amp is that it is an "error" amplifier, and different circuit configurations have different advantages.
