Question on Falstad Simulator
Discussion in 'The Projects Forum' started by, Jul 25, 2012.
    Jul 12, 2011
    Trying to simulate a simple timer using a transistor output driving a relay.
    Everything works ok except when the current decays and the relay drops out (it's a changeover relay ) the closed contact opens but instead of changing over with a snap the common arm moves over very slowly.
    In the real world of course the relay would snap and changeover.
    Is it possible to set it up to snap over?
  2. Markd77
    Sep 7, 2009
    I just tried it and it is snapping over, it is break before make and takes around 0.2ms to change over. That's pretty quick.
