Question on CMRR
Discussion in 'Homework Help' started by shiva bharadwaj, Jan 29, 2010.
  1. shiva bharadwaj
    Sep 29, 2008
    19
    Hi ,
    i have a question on opamps
    CMRR was given,
    the question was to find the output voltage,,,
    CMRR=60db
    it is a closed loop amplifier
    R1=R2=1k
    Rf=Rg=100k
    the voltage at non inverting terminal and inverting terminal are same and equal to one volt
    V+=V-=1
    so input differential mode voltage,Vd=0
    input common mode voltage,Vc=1
    can you please tell me how to find out the output voltage?
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    Deleted Deleted
  3. MikeML
    Oct 2, 2009
    5,451
    1,066
    This is obviously homework: I do not just provide answers lest you learn nothing.
    CMRR results from the fact that Rf/R1 ≠ Rg/R2. The two ratios are not exactly the same. This could be due to the tolerance of the resistors. The op-amp itself can exhibit some non-ideal behavior.
    Someone already told you that the effect of the imperfections cited above results in the output voltage containing an error which puts it within a -60db band of what the ideal circuit should be.
    I'll let you do the math...
