Hi
I have two problem both dealing with finding voltage using nodal anaylsis. When you have two dependant or independant voltage sources, Is the supernode equation determine identifying the node points separately for each voltage source or together as one?
For instance in the first question (refer to attachment doc)
View attachment tut2qns.doc
First SuperNode independent voltage source 3V : i1 = i3
Second SuperNode dependent voltage source 4Vo : i1 + i2
KVL for 4Vo - V = 0
rest of the equations
i1= (Vo-V)/3
i2= -3+V
i3= 4Vo-V
P.S
KVL for 4Vo - V = 0
i1= (Vo-V)/3
i2= -3+V
i3= 4Vo-V
P.S
