Question on BJT transistor sizing (W)
Discussion in 'General Electronics Chat' started by mbohuntr, Jul 6, 2013.
  1. mbohuntr
    Thread Starter Active Member
    Apr 6, 2009
    413
    32
    If I am using a piezo siren as a load, and it consumes 120mA, and I use it as a common emitter with a 1K base resistor, How do I determine the wattage for the transistor? I_{}b(12mA) + I_{}c(120mA) X V (12V) = Watts? = 1.3 watts? It doesn't seem like it should be that easy...
  2. #12
    Nov 30, 2010
    16,705
    7,358
    Let me take a stab at it...
    (12ma times Vbe) + (120ma times Vce) = P
    (.012 x .7) + (.12 x 12) = P
    .0084 + 1.44 = 1.4484W
    €Hunter likes this.
  3. €Hunter
    Jul 6, 2013
    33
    Looks about right to me.
    #12 likes this.
  4. €Hunter
    Jul 6, 2013
    33
    On a more serious note it looks terrible.
    #12 likes this.
  5. #12
    Nov 30, 2010
    16,705
    7,358
    I see. The piezo is in the collector side. That removes the 12V load from the transistor and the power rating goes way down...to about .0084W + Vce sat times .12A
    A schematic might have gotten through to me better.
    I'm not quite fully awake right now.
  6. €Hunter
    Jul 6, 2013
    33
    Hard stuff. Anyone who disagrees is either a fool or a liar.
    Wattage for the transistor would be the current that it is switching multiplied by the voltage drop across the junction.
    mbohuntr likes this.
  7. mbohuntr
    Apr 6, 2009
    413
    32
    So. . 7* 132ma?
  8. #12
    Nov 30, 2010
    16,705
    7,358
    No. Post #5 has it right. 12 ma times .7 (Vbe) plus .12A times the saturation voltage from collector to emitter, which is usually less than .7 volts.
    You haven't told which transistor you are using so I can't look up the Vce (saturated) of the transistor.
  9. mbohuntr
    Apr 6, 2009
    413
    32
    Sorry, forgot that... Right now I have a TO 92 3904 in the circuit.
  10. #12
    Nov 30, 2010
    16,705
    7,358
    Vce Sat at 120 ma seems to be .15 volts.
    Vbe at Ic = 100ma = .9V
    Power = (.012 x .9Vbe) + (.12 x .15Vce sat)
    P = .0108 + .018
    P = .0288 watts
  11. mbohuntr
    Apr 6, 2009
    413
    32
    Thank-you very much! Both you and CHunter! That is why I like this site so much. Good people, great help! It seems like I'm within the safe zone for this circuit. Thanks again! :D
  12. #12
    Nov 30, 2010
    16,705
    7,358
    That's what the "Thanks" button is for. Bottom right corner of the posting box. Hey, it's the only pay I get here.:(
