Question on a MOSFET
Discussion in 'General Electronics Chat' started by killivolt, Jul 23, 2015.
  1. killivolt
    Thread Starter Active Member
    Jan 10, 2010
    432
    351
    Has anyone seen this configuration? Out 2 and 3 are going to BNC outputs but I can't tell what the MOSFET is doing? Is the MOSFET only being used for its diode? Or is something fancier going on here?
    Thanks for any responses in advance.
    kv
  2. kubeek
    Sep 20, 2005
    4,687
    805
    I´ve seen this used as a level shifter.
  3. killivolt
    Jan 10, 2010
    432
    351
    From what I gathered on the "NET" most of the level shifters I see use Op-amp designs. I was thinking this was conditioning the voltage on OUT 2, and stabilizing it's voltage for a constant sink source.
    kv
    Edit: Oh, and thanks for the info :D
  4. jpanhalt
    Jan 18, 2008
    5,699
    909
    killivolt likes this.
  5. kubeek
    Sep 20, 2005
    4,687
    805
    Well this is not a level shifter in the linear sense, where you really would use an opamp, this is a level shifter for digital signals. If I remember correctly it can be used in both directions.
  6. cmartinez
    Jan 17, 2007
    3,698
    2,771
    Yes. I've used that configuration before, it's a bidirectional level shifter used to interface 5V to 3.3V logic. Check the attached document.
  7. cmartinez
    Jan 17, 2007
    3,698
    2,771
    Aaaargghhhh... John beat me to it! ....
  8. killivolt
    Jan 10, 2010
    432
    351
    Thanks all. I was thinking some sort of Logic circuit but; just couldn't fit it into anything I'm familiar. I used the BNC connections back sometime ago on old standard Def switchers but; SDI logic source was embedded for switching video. Now we have HD-SDI.
    Thanks again. kv
    Edit: I got some reading to do lol
  9. MaxHeadRoom
    Jul 18, 2013
    10,835
    2,506
  10. killivolt
    Jan 10, 2010
    432
    351
