Question non-related to Electronics
tadm123
Joined Nov 20, 2013
43
It's more of a general question and isn't about electronics but I'm guessing the question is relevant to fellow computer/electrical engineers. I just wanted some advise in what do you guys do to prevent eyes fatigue while on the job/ study.
My eyes constantly burn because of studying/working on the computer for longs period of time. It's becoming a problem really.
Any advise, and how do you guys personally deal with this? Thanks a lot.
tadm123
Joined Nov 20, 2013
43
Yeah, I will take an eye test.
I thought this was pretty common though for anyone who has been looking at the comp screen for a long time, and wanted some input on what do you guys do to deal with this.
Maybe it's not as common as I thought.
Veracohr
Joined Jan 3, 2011
772
Step away from the computer every once in a while. Take a few minutes, go get a drink of water, whatever. It's not only good for resting your eyes, but it's also good to get out of the chair for a few minutes. Also, don't work in the dark where the only light is from you monitor. Have a room light on.
atferrari
Joined Jan 6, 2004
4,771
Ambient lights? How far, in what position (ceiling, desk, in front of you, from the side...).
Do you need glasses? If so, do you use them? If you use reading glasses the focus for reading a book could be different from what is needed for your monitor at present distance. Even the position of the monitor staying just 10 cm higher /closer could make for a difference.
Is the monitor too bright (or maybe the opposite...)?
Myself, after studying for LONG hours in the Naval Academy for four years with fluorescent lights up there on the ceiling, I learnt to hate them.
My current setup. (With eight novels by the late García Márquez under the monitor to rise it 8 cm above the desk.)
JoeJester
Joined Apr 26, 2005
4,390
I failed my first eye test after a few years of working with monochrome monitors in the 1988. I went back a few days later and passed, so I'm assuming it was fatigue.
I'm 60 these days and use 1.75 x reading glasses. I notice I had a problem reading the numbers of chips about a decade or so ago.
I'm still good at distances, but closer requires the readers.
tadm123
Joined Nov 20, 2013
43
Nope, I don't need any glasses. I'm using a white fluorescent light bulb.
Here are some pics:
Here's the side view:
I put the brightness in the lowest of all in my laptop and feel comfortable with that, maybe I need to change that though.
Maybe having an actual lamp next to me might be a better option.
Anyways, thanks for all the replies.
34,469
I've spend many years at a computer screen for many hours each day without my eyes ever burning so perhaps you have an eye problem (the cure could be as simple as getting the proper eye-glasses).
Did an ophthalmologist say you don't need glasses or is that your opinion?
Does that table lamp shine into your eyes when you work? That can create fatigue.
tadm123
Joined Nov 20, 2013
43
Yeah, I did an eye exam in the routine checks about 5 months ago. And had 19/20 vision. But I forgot to mention this specific burning of the eyes problem.
And nope, the lamp doesn't shine in my eyes.
Sparky49
Joined Jul 16, 2011
833
Every 20 or 30 minutes, you really ought to at least move your eyes away from the screen and look at something far away for a minute.
If you think about it, in nature, your eye would be constantly examining and adjusting for features close, then far, then close, then in the middle, etc etc. However, when sat reading a monitor, it is very easy to simply stare at a screen which is they same distance from your head for hours. Your eyes don't even need to move to read everything, you just scroll to it. Also, I've been told that quite often people's blinking rates slow done too. So your eyes begin to dry out slightly - which is perhaps causing the pain.
Even when reading a book, your eyes are often doing the scrolling, and every time you turn the page, your eyes are forced to refocus, which is why people ca often read books/papers longer than read a monitor (without eye problems).
Sparky
THE_RB
Joined Feb 11, 2008
5,438
Set the room lighting to make the keyboard and paperwork the same brightness as the screen. That way your pupils don't need to readjust every time you look between the screen and keyboard etc.
The worst thing are black keyboards, it's almost impossible to get a black keyboard the same brightness as the screen.
