question ! lab power supply and lm3886 amp board ?
Discussion in 'Analog & Mixed-Signal Design' started by pastinsain, Jul 14, 2016.
  1. pastinsain
    Aug 25, 2012
    160
    why can't my hp 10 amp 40volt lab power supply drive the lm3886 amp ?
    the lm3886 works great with the 26vdc power supply that came with it, but when I try to power it with the hp 6267b lab supply , the amp will work for just a second then shuts down . Ive tried 3 other lab supplies and all do the same thing.
    I have the current set up to 5 amps and the volts set to 26vdc and the amp shuts down every time.
    now my ta2024 amps work great with the lab power supplies. what gives?
  2. AlbertHall
    Jun 4, 2014
    2,282
    450
    As it is a 10A supply why don't you set it to 10A and see whether that works?
  3. pastinsain
    Aug 25, 2012
    160
    I did that and the same thing happens
  4. benta
    Member
    Dec 7, 2015
    101
    24
    Normally, the LM3886 needs +26 V and -26 V.
    It is possible to run it single,supply, but then the circuit needs to be configured so.
    Are you certain that it is set up to run single-supply?
  5. pastinsain
    Aug 25, 2012
    160
    Yes the power supply that came with it powers both lm3886 boards , leads are 26+ , ground , neg
  6. benta
    Member
    Dec 7, 2015
    101
    24
    So, have you thought about what "neg" is? Perhaps -26 V?
  7. pastinsain
    Aug 25, 2012
    160
    That may be the answer -26v but why do the ta2024s work ok with the lab power ?
  8. AlbertHall
    Jun 4, 2014
    2,282
    450
    The TA2024 is intended to run from a single supply.
  9. pastinsain
    Aug 25, 2012
    160
    The 26v power that came with ithe lm3886 is a single supply . It powers both boards .
  10. pastinsain
    Aug 25, 2012
    160
    I appreciate your help, but I can't make any since out of it
  11. pastinsain
    Aug 25, 2012
    160
    I even tried connecting the lab power to just one lm3886 board and the same thing happens
  12. pastinsain
    Aug 25, 2012
    160
    All three lab power supplies have the factory default jumpers connected.
    Maybe if I tried connecting the neg jumpers on the rear of supplies to gnd . ?
  13. benta
    Member
    Dec 7, 2015
    101
    24
    I give up...
  14. pastinsain
    Aug 25, 2012
    160
    Thanks , however, there is something about these lab supplies " the DC is different compared to the dc in an amplifier in regard to the lm3886.
    that is for sure . What that difference is I would like to know ? I originally thought the lab supplies would be the cleanest power source you could drive an lm3886 with. but thats not the case ! bummer.
  15. atferrari
    Jan 6, 2004
    2,672
    785
    Test that PM amplifier with another capable PSU.
    Have you current limited your PSU? What is the setting?
  16. pastinsain
    Aug 25, 2012
    160
    yes I have set the current to 2amps ,,3amps ,6amps 10amps and no go. I would like to think DC is DC. but not in this case.
    I have tries 4 different PSUs and the same result
    hp6267b
    lambda 345a
    Kepco JQE 36-15
    HP 6289a
  17. benta
    Member
    Dec 7, 2015
    101
    24
    OK, for the last time:
    the OP does not understand what a dual supply is.
    The LM3886 needs a dual supply. And the original power supply will deliver +26/-26 V.
    The lab supply only delivers +26 V. OK?
    Benta.
  18. pastinsain
    Aug 25, 2012
    160
    the only dc power supply thats works is the one that came with the amp . What is so different about DC sources other than amp rating and regulated current limiting .
  19. pastinsain
    Aug 25, 2012
    160
    The supply that works is the one that came with the amp. And it is a single DC supply.
  20. benta
    Member
    Dec 7, 2015
    101
    24
    So what is "neg"?
    A picture would help.
