question in 8086/8088
Discussion in 'Embedded Systems and Microcontrollers' started by Embedded Lover, Jan 8, 2009.
  1. Embedded Lover
    Dec 22, 2008
    26
    Hello every body , i read this statement which i cant understand ,
    In an 8088/8086 the high addresses in the
    memory map should always be occupied by a
    ROM, while the low addresses in the
    RAM.
    why ?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    It pretty well worked that way for the old 8 bit microprocessors. The power on sequence loads the last 2 bytes of memory (FFFE & FFFF) into the address register as a jump vector. If you don't have ROM present, then nobody's home and the processor won't boot or start the process running.
  3. Embedded Lover
    Dec 22, 2008
    26
    yes got it ,and the 8088 processor start loading at address FFFF0H
    Thanks So much
