question from me about infra red led
Discussion in 'General Electronics Chat' started by cyril666, Mar 2, 2009.
  1. cyril666
    Feb 7, 2009
    12
    is possible to transfer analog signal using infra red led....without converting the analog signal to digital signal?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Given the narrow range of useful response in both the emitter and detector, plus the interference of ambient IR sources - not really. You might manage in a sealed tube over a distance of a few cm, but it's not practical over any distance. The inverse square law would require a recalibration every time the distance changed to reset the end points of response.
  3. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
    depends what you mean by digital. could convert voltage to frequency and transmit that. Since the frequency is a continuous value some would consider this a analog signal. Pulse width modulation might be considered analog as well. What is wrong with digital anyway? I would think you would want to do it the simplest way that is adaquate, not by prespecifying the technology.
  4. mik3
    Feb 4, 2008
    4,846
    63
    Better to use a variable intensity laser beam for this job. However, transmitting into digital form it is the best way.
  5. Darren Holdstock
    Feb 10, 2009
    262
    11
    It's possible, but not recommended. You'd need to bias the audio signal so it's always in the "lit up" range of the LED, and even then the LED characteristics are quite non-linear, so you'll have lots of distortion. I'd be tempted by a quasi-digital approach:
    Transmitter: Create a pulse-width-modulated (PWM) signal from the audio. This can be done simply with one decent comparator - feed the audio into one input, and a triangle wave into the other input. Remembering Nyquist, make the freq of the triangle wave at least 2X the max audio freq.
    Receiver: From a digital output (photodiode goes into transimpedance amp goes into a comparator), just reconstitute the audio with a low-pass filter. An RC filter should suffice if the sampling frequency is high enough.
  6. Audioguru
    Dec 20, 2007
    9,411
    896
    There are infrared headphones, speakers and conference translation products available. They modulate the IR with ultrasonic FM so the distortion and interference are extremely low.
