question for engineers about thair works
Discussion in 'General Electronics Chat' started by abhimanyu143, Aug 26, 2014.
  1. abhimanyu143
    Aug 25, 2014
    211
    respected members
    I Am Abhi doing Engineering in Electronics engineering. I have question for experienced engineers. If you will share your work experience. it will be grate help for fresher
    I am interested to know how you started your first job ,profession ,work , motivation
    some question for you
    1 how you started your first job?
    2 what is your job Title ?
    3 Describe your work ?
    4 which tools do you use in your work (hardware or software )
    5. what advice would you give to me as someone intersected in pursuing career path similar to your
    please explain little bit for fresher
  2. kubeek
    Sep 20, 2005
    4,687
    805
    Its been two years a few weeks ago that I work in my first engineering job.
    My title is hardware designer, but we are not a very big company, so no multilevel titles or anything fancy.
    I design circuits and pcbs for mostly railway automation system. For example recently I did a 6x1Gbps ethernet switch. I also prepare the production test software and testbeds for the products i am reponsible for and decide how they will be tested for EMC and EMI. Also I do some simple CAD work for the sheet metal cases.
    The company uses Orcad for schematics and pcb, and Solidworks for making the cases and other models.
    My advice would be to get as broad knowledge as you can, and never stop learning. You should know a good bit of everything: analog, digital, computing, HDL, high frequency, power.. to get good at your work. Then specialize in what interests you most.
    abhimanyu143 likes this.
  3. ScottWang
    Aug 23, 2012
    4,925
    777
    some question for you -- sounds like the teacher has a question for the students.
    3 Describe your work ? -- sounds like request to do, not asking.
  4. abhimanyu143
    Aug 25, 2014
    211
    not necessary for everyone. Its your wish. If you want to tell about yourself.
