Question for a formula related to electrical power?
Discussion in 'General Electronics Chat' started by samy555, Aug 17, 2014.
  1. samy555
    Thread Starter Active Member
    May 24, 2010
    116
    Hi
    When I read the page on the link:
    http://www.electronics-tutorials.com/amplifiers/negative-feedback.htm
    I found this formula for calculating the output power of RF amplifier:
    2 * Po = [Vcc - Ve][SUP]2[/SUP] / R
    Also found the same formula in the book: ‎ARRL - Experimental Methods in RF Design, where:
    Po: the output power
    VCC: the battery voltage
    Ve: the emitter voltage
    R: the load resistance
    I think that number 2 came from a conversion of the Vp to rms
    My question is: Why [Vcc - Ve][SUP]2[/SUP] and not simply Vc[SUP]2[/SUP] ; the ac collector voltage??
    Thank you
  2. GopherT
    Nov 23, 2012
    6,297
    4,019
    Some amplifier power supplies have, positive and negative rails with a common (0V) at near the midpoint. Since mid-point is not exact, and other reasons, they just say you should use the total voltage swing positive (max) to negative (min).
    Your illustration is hard to read because SUP doesn't work on this forum.
    samy555 likes this.
  3. studiot
    Nov 9, 2007
    5,005
    515
    I don't think you have this formula quite correct.
    The derivation is as follows:
    The maximum sine wave that can be fitted between two rails is a rail to rail sine wave.
    The rails may be ± about earth or they may be + and 0.
    I will take the value to be + and 0 for simplicity. (the zero is usually Ve and the plus is usually almost Vcc)
    So let the rail to rail voltage be V
    Then this the the peak to peak voltage
    So the peak is half this ie V/2
    So the RMS value is V/(2√2)
    If we apply this to a load of R ohms then the RMS current is V/(2√2R)
    So the RMS power = Irms x Vrms = V/(2√2R) * V/(2√2)
    {P_{rms}} = \frac{{V^2}}{{8R}}
    This is for a single ended output, often called a half bridge.
    A full bridge circuit, often called an H bridge, produces four times this.
  4. samy555
    May 24, 2010
    116
    thank you GopherT
    Why is the biggest Up swing of the signal is to Ve??
    How this is done, I hope that you explain to me that, if possible
    thank you very much studiot
    I need to know about the maximum swing
  5. t_n_k
    Mar 6, 2009
    5,448
    783
    At some instant the capacitor might be charged to (Vcc-Ve) with the transistor saturated. At resonance the capacitor voltage can fully reverse polarity at some later instant - say as the transistor goes into cut-off. So the capacitor voltage will have swung nominally between ±(Vcc-Ve) over a full resonant sinusoidal cycle. If the load R sits across this voltage swing then the average power would be
    P_{av}=\frac{{\(\frac{(Vcc - Ve)}{\sqrt{2}}\)}^2}{R}=\frac{{(Vcc - Ve)}^2}{2R}
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    Hi samy555,
    With respect to your posted schematic one needs to first keep in mind that the load power is also determined by the input signal drive.
    The value given by the formula assumes that the input drive is sufficient to ensure the load voltage swing is the maximum achievable for the given circuit conditions.
    As shown, the amplifier is probably intended to operate in Class A mode. However, increasing the input signal drive level will ultimately force the operation into a less linear mode which may be difficult to clearly define without actually resorting to building the circuit. In fact, it may require some over-driving of the amplifier into partial non-linear operation which ensures one maximizes the load voltage swing.
    In your schematic Ve will have a mean value - presumably that value which one would plug into the formula. But since the mean emitter voltage also has a superimposed AC component (approximately equal to the AC input signal voltage) the exact value of Ve at the corresponding load voltage minima won't be Ve_mean. The difference won't be that significant but observable.
    In any event the formula will give a good starting estimate for the achievable maximum load power - provided the circuit is well behaved in other respects.
