I am reading about the zener diode, and from my understanding the zener diode adjusts its internal resistance and so the current going through it to keep the voltage across it to a specific voltage characteristic of the zener diode.
Usually, for resistors for example, the independent variable is voltage and the current is figured out by the voltage. but in the case of the zener diode it seems like it's backward.
How does it work exactly? If the state of the diode (whether current is flowing or not) is determined by the voltage applied across it then how come the it also controls its current do keep a specified voltage across it?
I'm having trouble understanding what is the independent variable and what depends on the circuit and the diode.
What happens when I apply some arbitrary voltage across it's end, say 15v, to a diode rated 5v?
