question about transistor resistor logic
Discussion in 'Homework Help' started by caoadon, Aug 11, 2014.
  1. caoadon
    Jul 11, 2014
    24
    Can an inverter logic gate invert a high frequency pulse? (1MHz)
    thanks
  2. MrChips
    Oct 2, 2009
    12,625
    3,451
    Why not?
    7404 TTL inverters are good to at least 25MHz.
  3. alfacliff
    Dec 13, 2013
    2,449
    428
    but RTL inverters are a lot slower.
  4. caoadon
    Jul 11, 2014
    24
    Oh could i use a 7404 for just a single input and output? there are so many pins
  5. caoadon
    Jul 11, 2014
    24
    nvm dumb question. but thanks i'll look into buying a TTL
  6. shteii01
    Feb 19, 2010
    3,500
    511
    Each gate is independent of all others. Just use one.
    Or.
    Buy chip that only has one gate, and meets your frequency requirement.
  7. MikeML
    Oct 2, 2009
    5,451
    1,066
    Make your own: one NPN transistor and two resistors...
  8. caoadon
    Jul 11, 2014
    24
    are there two optimal resistors i can use? I've seen so many variations of it
  9. shteii01
    Feb 19, 2010
    3,500
    511
    Depends on input voltage and current, and desired output voltage and current.
  10. caoadon
    Jul 11, 2014
    24
    5V pulse with a max current of 400μA?
    I just want an exact inversion of it.
    Sorry I can't think of the math right now...
  11. MikeML
    Oct 2, 2009
    5,451
    1,066
    In retrospect, the 400uA makes it tough to do with a simple NPN (or with TTL or even LSTTL), I would use a 4000 series CMOS inverter.
  12. MrChips
    Oct 2, 2009
    12,625
    3,451
    You can get single gate components in a SMD package.
    Or go with a single NPN transistor with two resistors as shown here:
    The voltage source can be +5V instead of the +12V shown.
  13. caoadon
    Jul 11, 2014
    24
    i just bought an NTE7404 hex inverter. Do i need to use resistors with them?
  14. MrChips
    Oct 2, 2009
    12,625
    3,451
    No need for additional resistors for your application.
    You can use a single gate and leave the remaining five not connected.
    If you want extra output power you can parallel multiple gates together.
    400μA could be a limiting factor. Try it with one gate first and see what happens.
  15. caoadon
    Jul 11, 2014
    24
    It seems to be inverting fine. Do I not need to do impedance matching? THeres a 50ohm input impedance.
  16. MrChips
    Oct 2, 2009
    12,625
    3,451
    Where exactly is the 50-ohm impedance?
  17. caoadon
    Jul 11, 2014
    24
    The ultrasound im working with outputs a signal that i want to invert. so i sent it through the hex inverter. once inverted, the output of the hex inverter is the input of a laser with a 50ohm input impedance
  18. MikeML
    Oct 2, 2009
    5,451
    1,066
    So this is an analog signal? If so, you need a medium fast modern opamp to invert the signal while retaining its fidelity; not a logic inverter...
  19. MrChips
    Oct 2, 2009
    12,625
    3,451
    Perhaps you should go into more details as to what you are attempting to do.
  20. caoadon
    Jul 11, 2014
    24
    I am trying to invert a pulse and input it into a laser. The laser has a 50ohm input impedance.
    I just bought a 7406 hex inverter open collector.
    The 7404 didn't work. or it didn't invert the signal exactly (it was around a 2V pulse compared to the original 5V) because of the 50ohm impedance.
