Question about transformers
Discussion in 'General Electronics Chat' started by Thuktun, Apr 2, 2015.
  1. Thuktun
    Apr 2, 2015
    15
    Hello everybody, I'm new to electronics as a hobby so bear with my lack knowledge. I have access to all sorts of electronics junk in my job and I learned long before I got into this to not throw anything away. I have a couple of transformers labelled 347v 60hz 120v 30va. It's my understanding this steps down 347v to 120v at a max 1/4 amps, correct? My question is, can I use this to step down 120v and what would be the effects? Meaning I would get about 40v but what amperage? Would it still be 1/4 amps or would it still be 30va so work out to 3/4 amps or would it be some other value all together?
  2. Kermit2
    Feb 5, 2010
    3,852
    968
    using 30 VA is the safe bet, but you likely could draw 10-20% more without a problem. monitor temp rise to determine limits. intermittent use allows higher current draws with cool down in between active periods.
  3. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,524
    If you ever needed 347vac you could run it backwards off of 120v!;)
    Max.
  4. alfacliff
    Dec 13, 2013
    2,449
    428
    I sould not increase the output current, it's set by the wire size, and keeping the va the same would double the currrent.
  5. #12
    Nov 30, 2010
    16,704
    7,354
    alfacliff has it. The diameter of the secondary wire is designed to carry 1/4 amp. Try to get 30 VA out of that at 1/4 the voltage and the heat goes up to burning level after just a few minutes.
    Gdrumm likes this.
  6. Thuktun
    Apr 2, 2015
    15
    Thanks guys. I figured that was the case, just wanted confirmation.
    I got some magnetic ballasts too, this is the biggest. I have no idea what I may use them for.
  7. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,524
    They are stamped auto transformers and are Holophane!!
    Max.
