Hello, all:
So I have to deal with transformers for my project. From my understanding, a typical transformer one sees in a textbook has two parameters N1 and N2. The relation between Vin and Vout is then Vout = (N1/N2 ) Vin. In other words, N1:N2 is the ratio. If N1 < N2, then it is a step down transformer.
However, most transformers one can buy have rating of Vin and Vout with specific numbers. For example, Vin = 12 V and Vout = 6 V. I do not understand how this works. If I input a 9-volt voltage to this transformer, what would happen? Does it have to take 12 V as its input?
Thank you.
Thank you.
