Question About The Origin Of The Solar System
Discussion in 'General Science' started by Glenn Holland, Dec 29, 2015.
  1. Glenn Holland
    Dec 26, 2014
    359
    114
    It's quite well known and accepted that the solar system originated from debris from a supernova explosion several billion years ago and part of the debris eventually accreted into the sun and the planets.
    Has anyone identified the epicenter or source of the supernova explosion from which we came about? The remains would now be just a nebula (the remnants of an ancient supernova). However, it seems that astronomers might be able to determine the direction or path from which the debris came and that would lead them to that particular nebula.
    Monika Verma likes this.
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    As I understand it it is not just one, but a collection of several over time. There might have been a shock wave from one in particular that caused the coalescence, but stellar nurseries are pretty documented.
  3. Glenn Holland
    Dec 26, 2014
    359
    114
    Massive stars that were capable of producing a supernova were created in the early days of the universe and they lasted only a few 100 million years.
    So there were probably millions more of these stars than what we observe today. Considering the huge number of stars going kaboom, the early days of the universe must have looked like the 4Th Of July.
    Also when these stars blew, the plasma and "embedded" magnetic fields was scattered throughout space. Hans Alfen cleverly demonstrated that embedded magnetic fields could compress the material to a much higher density than just the force and pressure of gravity alone.
  4. KL7AJ
    Nov 4, 2008
    2,047
    295
    There SEEMS to be a general center of gravity of the universe (with a lot more localized ones). From a very wide angle, the universe seems to be rather flat.....which suggests rotation around some point. It's not equally distributed in a semi-spherical blob as one might suspect.
  5. joeyd999
    Jun 6, 2011
    2,757
    2,931
    Yes. With the Grand Finale first.
  6. joeyd999
    Jun 6, 2011
    2,757
    2,931
    No! The fact that the universe appears flat (i.e. the same no matter which direction you look) implies that there is no "center". That is, unless we are it.
    In fact, the theory of cosmic inflation, if true, says that the universe is *far* larger than the distance light would have traveled since the beginning of the universe. This, again, implies there is no center.
  7. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,521
    Further back than that, what/how originated matter in the first place?
    Max.
    atferrari likes this.
  8. Glenn Holland
    Dec 26, 2014
    359
    114
    If the Big Bang was a symmetric event (the debris followed a radial path), the universe would resemble a disk or possibly a sphere.
    However, it could have been asymmetric with more debris ejected in one general direction. I suppose a supernova explosion could also be asymmetric and eject debris in one direction.
    That would also produce a recoil effect and the neutron star or black hole would travel away from the location of the original star.
  9. KL7AJ
    Nov 4, 2008
    2,047
    295
    Here's another monkey wrench to throw into the gearbox. For a hundred years or so, we've assumed the speed of Light is the limiting factor, and we've estimated astrophysical distances based on that limitation.
    Enter "spooky action at a distance"....the medieval theory we THOUGHT Newton et all had debunked once and for all. Photon (and other particle) entanglement seems to transmit information if not INFINITELY fast, then at least orders of magnitude faster than light. If this is the case, it COULD be that far distant objects are a lot more distant than we thought. Or, reciprocally, if our distance estimates are right, then the AGE of the universe is a lot less! How far is a "light year" for spooky-action-at-a-distance events? Who knows?
  10. Glenn Holland
    Dec 26, 2014
    359
    114
    That's the confounding, perplexing, and conundrumous question that makes me dizzy so I have to stop thinking about it before I fall on the floor. :p
    #12 likes this.
  11. KL7AJ
    Nov 4, 2008
    2,047
    295
    I don't know about YOU, but I'm certainly the center of MY universe. :)
  12. joeyd999
    Jun 6, 2011
    2,757
    2,931
    You think the universe revolves around you...but that is only because you share a planet with me.
  13. KL7AJ
    Nov 4, 2008
    2,047
    295
    D'ya thing there's room for the both of us? :)
  14. Glenn Holland
    Dec 26, 2014
    359
    114
    Light provides the image of what happened at a given location in the past time, but the image cannot be transmitted faster than the speed of light.
    Bell Telephone Labs claims to have observed the remnants of the Big Bang (microwave radiation) being emitted from the outer edge of the explosion. Although the matter may have been ejected at relativisitic speed, it couldn't travel at the speed of light. Therefore, we can still observe the radiation coming back from the original shock front.
  15. Glenn Holland
    Dec 26, 2014
    359
    114
    The reason why you perceive the universe revolving around you is because your creditors are coming in at you from all directions. :confused:
  16. KL7AJ
    Nov 4, 2008
    2,047
    295
    Hey Glenn...what's that device in your photo. If I didn't know better, I'd say it's a seismology chart recorder.
  17. Glenn Holland
    Dec 26, 2014
    359
    114
    Yes, that is a seismograph recorder with the late Charlie Richter posing in back of it.
    The photo was taken at the CalTech Seismological Laboratory around 1965.
  18. KL7AJ
    Nov 4, 2008
    2,047
    295
    Wow! Did you know him?
  19. Glenn Holland
    Dec 26, 2014
    359
    114
    I met the guy once around 1975 and had him autograph my copy of his book called "Elementary Seismology".
    I don't know what an autographed copy of Richter's book is worth, however it's kept in a sealed plastic box.
  20. KL7AJ
    Nov 4, 2008
    2,047
    295
    I can guarantee you it's worth a pretty penny! I have one of my dad's old helicopter engineering books signed by Igor Sikorsky. I have that well crypted too. :)
