I am trying to build a regulated power supply controlled by a microprocessor. I have the following arrangement working. I operate a CAT5111 digital resistor from an Arduino board, and the 0 - 5 volts variable that I can get out of that is run through an LM358 opamp configured as a 5 to 1 noninverting amplifier, so my 0 - 5v. is now 0 to 25v. Next I take that variable voltage and feed it into the adjust leg of an LM317, effectively as the ground level seen by the adjust pin. When this variable voltage is 0, the LM317 is configured to deliver 5 v. When I move the variable voltage to the adjust pin up, I get an LM317 range from 5 - 30 v., which is exactly what I want.
Now it appears to me that the load current for the LM 317 in no part flows through the adjust pin, but if it did, I suppose the OPAMP output, which looks like ground to the LM317, would not sink current, or at least only a little. I am hesitant to load test this arrangement until I know that it won't cook my opamp.
Can anyone enlighten me as to the reliabilty of this circuit?
Thanks in advance for any insights.
