Question about the importance of 1% resistor in thermostat circuit
Discussion in 'General Electronics Chat' started by tracecom, Jun 6, 2010.
  1. tracecom
    Thread Starter AAC Fanatic!
    Apr 16, 2010
    3,878
    1,396
  2. retched
    Dec 5, 2009
    5,201
    313
    I suppose if you are trying to get an accurate temperature, you want to build it from accurate parts.
    here tis:
  3. Bychon
    Member
    Mar 12, 2010
    469
    41
    I'd say, "yes". All the thermistors I've met were 1% accuracy. No reason to throw that away for a 12 cent resistor.
  4. tracecom
    Apr 16, 2010
    3,878
    1,396
    Does RV1 compensate for any variance in R4?
  5. Bychon
    Member
    Mar 12, 2010
    469
    41
    No. It sets the switching temperature.
  6. tracecom
    Apr 16, 2010
    3,878
    1,396
    I guess that is where I am confused. The circuit doesn't actually display the temperature anywhere. In use, you have to have a separate thermometer in order to set RV1 to switch at the temp you want it to, so it seems that the precise value of R4 doesn't matter. I'm not disputing what you say; I just don't understand.
  7. Jaguarjoe
    Apr 7, 2010
    770
    90
    Maybe they want 1% because it might have a better temperature coefficient than a garden variety resistor. The actual value does not need to be 1% accurate because if its not, you'll just tweak RV1 a tad to make up for the slight difference in value.
  8. Bychon
    Member
    Mar 12, 2010
    469
    41
    I have a chart of a 10k 1% thermistor and it shows 2 1/2 degrees (Centigrade) error for a 10% difference in R4 (at a center point of 25 C). If that doesn't matter to you, throw the 1% resistor away and put in a 10% resistor.
  9. tracecom
    Apr 16, 2010
    3,878
    1,396
    That's what I thought, but I'm no expert. As a matter of fact, the R4 resistor that ships with this Velleman kit has a 5% tolerance.
  10. Bychon
    Member
    Mar 12, 2010
    469
    41
    Gee...you had all of us thinking a 1% resistor came with the kit and you were thinking about throwing it away.
  11. tracecom
    Apr 16, 2010
    3,878
    1,396
    :) No, just the opposite; I was wondering if I needed to change to a 1%. Seriously, is that chart you mention something that you can provide a link to? Maybe I could learn something.
  12. Bychon
    Member
    Mar 12, 2010
    469
    41
    I don't know how to do a link to my filing cabinet. Maybe I can scan it.
    tracecom likes this.
  13. someonesdad
    Jul 7, 2009
    1,585
    141
    Bychon's scan looks like a sheet I have for an old YSI thermistor. Don't assume it applies to any other thermistors except the indicated model. You can go to Measurement Specialties' site and get data sheets on their different thermistors (they bought YSI).
  14. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Well, a metal film resistor would have better stability than a carbon or carbon film, and would also have lower noise.
    However that circuit isn't aimed for precision anyway, so it's really "Much Ado About Nothing".
    BTW, 1N4148's were poor choices for D1, D2. Expect them to burn up after the circuit's been in use for awhile. You could swap them out for any 1N400x series, or if you prefer some 1N5817's.
