Question about Switch-Mode PSU Conversion to Bench Supply
Discussion in 'General Electronics Chat' started by willgtl, Aug 2, 2015.
  1. willgtl
    Sep 20, 2011
    5
    A while ago I fashioned a lazy-man's bench power supply out of an old computer power supply. I simply lopped off the ATX main and grounded PS_ON with one of the 7 grounds (I don't remember why I just didn't take a couple of male pins and fashion a pluggable wire).
    Over time, I'd make a mistake and short it out and to get it to power on again I would have to ground PS_ON to a different ground. I don't know a ton about the internal workings on a switch-mode PSU but my thinking is that each ground has a thermal fuse, so when it goes the ground is no longer connected. Is my thinking correct or wrong? Thanks!
  2. ISB123
    May 21, 2014
    1,240
    531
    PSU has a Fuse,PTC Thermistor and a Resistor for protection.The only reason GND isn't working anymore is if you burned the trace/wire.
    willgtl likes this.
  3. willgtl
    Sep 20, 2011
    5
    Ah, thank you!
  4. ISB123
    May 21, 2014
    1,240
    531
    Take a multimeter if you have and do a continuity test.
