I think it's a synchronous motor, it plugs straight to 110VAC and drives a fan blade.. Motor hums but doesn't turn when powered.
It has a cap rated 2uF, I replaced it still doesn't move. I replaced it again with a 4uF and can get it to move when I spin start it with my fingers. Q: Is it ok to double the cap to 4uF like that?
Also, can I oil the gap in between the rotor and the stator? I did that and seems fine as it's spinning now. But should that gap not be oiled?
