question about speaker power
huitlacoche
Joined Apr 29, 2009
9
I'm interested in experimenting with tactile tranducers but I'm not terribly versed in how wattage ratings will affect them. I've been looking at some cheaper 8 ohm transducers that can handle about 3-5W rms. I have an amp that supplies about 25w. Now I'm thinking this will literally destroy the transducer and that I should go with a more expensive one that can handle 25 watts. Is my understanding of this flawed and the cheap ones will be fine?
Thanks!
-- Mark
K7GUH
Joined Jan 28, 2011
190
You could build an array of such speakers connected in series and in parallel so as to give you 8 ohms impedance. The array of 8 such speakers could handle 25 watts.
#12
Joined Nov 30, 2010
18,224
You could refrain from turning the amplifer as high as it will go. That will send less power to the speaker.
34,470
Keeping the volume down will keep the transducers from being over loaded. If you are worried about someone turning the volume too high, you can add a normal (not slow-blow) fuse in series with the speaker connection. A 700mA fuse will limit the power to about 3.9W.
