I bought an amplifier circuit board, assembled but with no case or power supply, and I'm using the transformer, caps, and diodes out of a broken old amp. Something I've wanted to know how to do for a while even before this project is slow charging capacitors from the power supply while still having full unrestricted amps and volts available to the load. Ideally I want just a temporary slow charge circuit to avoid too big of a power surge when the device is powered on. I kept the switch and fuse that is connected to the transformer out of the old amp and I don't want to be blowing fuses.
I'm not familiar enough with circuits and reading schematics to easily find the answer through research. I've spent a couple hours googling things and just can't find what I need. I've thought about using diodes, but that involves a voltage drop, I thought varistors could be useful to but I know little about them and their datasheets seem to only show surge protection specs instead of continuous use specs. I'm thinking a switch would work, but I don't know how well a mosfet would work for a delayed turn on to bypass the initial slow charge resistor and still let ripple current flow in and out.
