question about showing a picture on GLCD (( avr and codevision))
Discussion in 'Embedded Systems and Microcontrollers' started by roberty, May 12, 2012.
  1. roberty
    Aug 18, 2010
    11
    hi every one
    this program that is writen by myself has a problem that i cant solve it...
    if you have some experience in working whit GLCD's you know that an image can be converted to a BMP format file and then by using the " flash " datatype we can show that image on the glcd....
    ok...i write my programms in codevision 2.05.3 and as you know this version has a lot of functions to work whit GLCDs.
    here is the code...
    Code ( (Unknown Language)):
    1. #include <delay.h>
    2. #include <mega32.h>
    3. // Graphic LCD functions
    4. #include <glcd.h>
    5. // Font used for displaying text
    6. // on the graphic LCD
    7. #include <font5x7.h>
    8.    GLCDINIT_t glcd_init_data;
    9.   int i,j,p,a2d;
    10.   int k=0;
    11. int data[128];
    12. flash unsigned char picture1[]={
    13.  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x50,0x40,0x00,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x00,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    14.  0x00,0x10,0x20,0x20,0x20,0x2C,0x1C,0x04,0x04,0x05,0x05,0x00,0x00,0x04,0x04,0x04,0x04,0x05,0x05,0x06,0x04,0x04,0x04,0x02,0x04,0x04,0x02,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x04,0x06,0x05,0x05,0x04,0x05,0x07,0x04,0x14,0x05,0x00,0x03,0x00,0x00,0x00,0x20,0x20,0x10,0x09,0x00,0x00,0x00,0x00,0x00,0x04,0x04,0x04,0x02,0x04,0x04,0x04,0x06,0x05,0x05,0x05,0x07,0x00,0x00,0x20,0x20,0x10,0x09,0x00,0x00,0x00,0x00,0x00,0x04,0x04,0x04,0x04,0x14,0x14,0x04,0x04,0x02,0x03,0x05,0x06,0x04,0x04,0x05,0x05,0x06,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    15.  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    16.  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    17.  0x00,0x02,0x04,0x04,0x04,0x05,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x02,0x01,0x00,0x00,0x00,0x00,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    18. 0x00,0x10,0x20,0x20,0x20,0xA0,0x20,0x20,0x20,0x28,0x00,0x00,0x00,0x10,0xA8,0x20,0x20,0x21,0x28,0x20,0x28,0xA8,0x28,0x30,0x20,0x00,0x00,0x00,0x00,0x00,0x80,0x00,0x02,0x00,0x80,0x48,0x00,0x1F,0x00,0x00,0x00,0x00,0x00,0x88,0x20,0x20,0xA0,0x28,0x20,0x20,0x21,0x20,0x2C,0x00,0x00,0x00,0x00,0x20,0x20,0x22,0x20,0x20,0x28,0x28,0x28,0x30,0x20,0x20,0x00,0x1C,0x00,0x00,0x00,0x00,0xA8,0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    19. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x00,0x00,0x00,0x00,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
    20. };
    21.
    22.
    23. // ADC interrupt service routine
    24. interrupt [ADC_INT] void adc_isr(void)
    25. {
    26. if (k<128)
    27.     {
    28.       k++;
    29.      data[k]=ADCW;
    30.       glcd_setpixel (k,data[k]);
    31.      ADCSRA|=1<<ADSC;
    32.      }
    33. }
    34.
    35. void main(void)
    36. {
    37. PORTB=0x00;
    38. DDRB=0x00;
    39. // Graphic LCD initialization
    40. // The KS0108 connections are specified in the
    41. // Project|Configure|C Compiler|Libraries|Graphic LCD menu:
    42. // DB0 - PORTC Bit 0
    43. // DB1 - PORTC Bit 1
    44. // DB2 - PORTC Bit 2
    45. // DB3 - PORTC Bit 3
    46. // DB4 - PORTC Bit 4
    47. // DB5 - PORTC Bit 5
    48. // DB6 - PORTC Bit 6
    49. // DB7 - PORTC Bit 7
    50. // E - PORTD Bit 0
    51. // RD /WR - PORTB Bit 1
    52. // RS - PORTB Bit 2
    53. // /RST - PORTB Bit 3
    54. // CS1 - PORTD Bit 4
    55. // CS2 - PORTD Bit 5
    56. // Specify the current font for displaying text
    57. glcd_init_data.font=font5x7;
    58. // No function is used for reading
    59. // image data from external memory
    60. glcd_init_data.readxmem=NULL;
    61. // No function is used for writing
    62. // image data to external memory
    63. glcd_init_data.writexmem=NULL;
    64.
    65. glcd_init(&glcd_init_data);
    66.
    67. [COLOR="Red"]glcd_putimagef(0,0, picture1,GLCD_PUTCOPY);
    68. delay_ms(2000);[/COLOR]
    69.
    70. while (1)
    71.       {
    72.
    73.         glcd_clear();
    74.       for (i=0;i<128;i+=2){
    75.       glcd_setpixel (64,i);
    76.       }
    77.       for (j=0;j<128;j+=2){
    78.       glcd_setpixel (j,32);
    79.       }
    80.       glcd_putcharxy( 1, 56, 'v');
    81.       glcd_putcharxy( 66, 56, 't');
    82.       glcd_putcharxy( 6, 56, '=');
    83.       glcd_putcharxy( 71, 56, '=');
    84.       selectch();
    85.       ADCSRA = 0b11100111;
    86.       ADMUX = 0b01100000;
    87.       SFIOR = 0x00;
    88.       a2d = ADCW;
    89.       p =  (1024 - (a2d))/16;
    90.       for( i=0;i<1024;i++){
    91.       for(j=0;j<=a2d ; j++)
    92.       glcd_setpixel (p,i);
    93.       }
    94.
    95. for (i=0;i<127;i++){
    96. do{
    97. i=0;
    98. glcd_setpixel(i,p);
    99. delay_us(100);
    100. i++;
    101. if(i==128)
    102. i=0;
    103. }
    104. while(1);
    105. }
    106. }
    107. }
    108. ///////////// defination of selechch.
    109. void selectch (void)
    110. {
    111. do{
    112. //// first key for first channel
    113. if(PINB.0)
    114.    {
    115.     delay_ms(20);
    116.     if(PINB.0)
    117.     {
    118.     glcd_outtextxyf (2,5,"SEL CH1");
    119.     delay_ms(400);
    120.     for(i=0;i<15;i++){
    121.     for(j=0;j<45;j++){
    122.     glcd_clrpixel (i,j);
    123.     }
    124.     }
    125.      ADMUX = 0b01100000;
    126.        while(PINB.0);
    127.     }
    128.    }
    129. else
    130. /// secind key for second channel
    131.    if(PINB)
    132.    {
    133.     delay_ms(20);
    134.     if(PINB)
    135.     {
    136.     glcd_outtextxyf (2,5,"SEL CH2");
    137.     delay_ms(400);
    138.     for(i=0;i<30;i++){
    139.     glcd_clrpixel (2,i);
    140.      ADMUX = 0b01100001;
    141.      }
    142.        while(PINB);
    143.     }
    144.    }
    145.  else
    146.  ///// third key for both channel ((hamzaman ))
    147.    if(PINB)
    148.    {
    149.     delay_ms(20);
    150.     if(PINB)
    151.     {
    152.     glcd_outtextxyf (2,5,"SEL CH1&2");
    153.     delay_ms(400);
    154.     for(i=0;i<35;i++){
    155.     glcd_clrpixel (2,i);
    156.     }
    157.     do{
    158.      ADMUX = 0b01100001;
    159.      delay_ms(10);
    160.      ADMUX = 0b01100000;
    161.      delay_ms(10);
    162.      }
    163.      while(1);
    164.      while(PINB);
    165.     }
    166.    }
    167.    }
    168.    while(1);
    169. }
    170.
    the problem is shown whit red color.
    when i use this function i dont know why but nothing shows on the glcd...!!
    so i wanted to ask you if you had some similar experience in sending a picture to your glcd whit this metod.... how can i send that " flash" variables and see my picture on glcd...?
    is there anything wrong whit my code...?
    remember that the code above is just a pice of my programm.
    thanks for the help.
