Hello, I have several RGB 5MM LED that I have been playing around with an Arduino by using PWM. When I try to mix colors, the result appears to be three separate LED's right next to each-other, rather then one fluid color. My LED's are water clear, rather then diffused could this be why? Or is it something else?
I am using simple 5V power supply from the Arduino and I am using 360 Ohm resistors for each color.
