Question About Rectifier Types
Discussion in 'General Electronics Chat' started by lubi, Mar 20, 2007.
  1. lubi
    Mar 6, 2007
    12
    could anyone tell me what are the differences b/t bridge FW rectifier and centre tapped FW rectifier
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Do not hijack three year old threads.
  3. Salgat
    Dec 23, 2006
    215
    Pretty sure its half the Peak to Peak voltage for Center tapped.
  4. lubi
    Mar 6, 2007
    12
    what about the peak inverse voltage,why do we use a bridge rectifier instead of the centre tapped one
  5. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    A bridge rectifier will work with any transformer, center-tapped or not. Example: a 12Vrms center tapped secondary will serve to supply either 17Vpk or 8.5Vpk, or two each 8.5Vpk using two bridge rectifiers using a bridge rectifier. The same transformer will supply only 8.5Vpk using a two-diode full wave rectifier.
