Question about Rds(on) of a power MOSFET
Discussion in 'General Electronics Chat' started by hunterage2000, Feb 16, 2016.
  1. hunterage2000
    Thread Starter Active Member
    May 2, 2010
    402
    Can someone tell how Rds(on) of a power MOSFET is calculated when operated as a switch?
  2. Jony130
    Feb 17, 2009
    3,993
    1,116
    We simply check the value in data sheet for a given MOSFET.
  3. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,699
    1,298
    It isn't calculated. It is stated on the datasheet, usually under specific conditions such as a 10 V drive signal and a stated pulse width.
    ak
  4. ErnieM
    Apr 24, 2011
    7,439
    1,627
    How fast is this thing switching?
    If just every so often than Rds on times source current is a decent estimation of device power.
    Switch that sucker on and off fast, as is done in a switching power supply, and the losses are dominated by switching losses as the device goes off to on (minority) and on to off (mostly).
    These are due to the short period when the device voltage is increasing but the load current is still on. It is but a brief period but they do add up.
