question about pic16f628
Discussion in 'The Projects Forum' started by ht systems, Aug 16, 2011.
  1. ht systems
    Aug 2, 2011
    71
    hello , how could i choose the value of the crystal and do i need to put an amplifier on the output to lead an AND gate or NOT gate ?
  2. upand_at_them
    May 15, 2010
    246
    29
    The crystal is up to you, limited by the datasheet spec. If you're only driving a few gates, you don't need a buffer on the output.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    If you use a PIC16F628A instead, they have an internal 4MHz oscillator, so you would not need a crystal unless you need better than ~1% accuracy.
    The I/O pins can source or sink ±20mA+, but there is also a package limit. See the Electrical Specifications section in the datasheet.
  4. ht systems
    Aug 2, 2011
    71
    thank you , your words help me
  5. eblc1388
    Nov 28, 2008
    1,542
    102
    16F628 also has an internal 4MHz RC oscillator, albeit not factory calibrated to within 1% accuracy.
